Posted by spiffy1 on September 22, 2008 at 14:11:53 from (70.41.136.71):
In Reply to: Stuck 22-36 posted by LBSMJS on September 21, 2008 at 18:46:52:
fixerupper said: (quoted from post at 20:35:06 09/22/08) An Idea I heard just this weekend is to pull the head and lay a rag soaked with ATF on the piston, then light the rag on fire. The person I talked to claimed the ATF is a very high detergent oil and as the rag burns and heats the cylinder, hot oil will creep down the sides of the piston. Anyone else heard of this idea? Jim
Heard of that but never tried it; also a variaiton without pulling the head by putting a wick down the spark plug hole. In this case, I think head gaskets are pretty available, but I'm trying to go with the simplest techniques first.
I've also read about using a "portapower" instead of compressed air, but unless the pistons can be clear of the crank, I just imagine nasty projectile motion. Also, I have no idea of the pressure those heads can take [I'm pretty sure 1Ksi would be OK, but have my doubts about 2 or 3], a bit hesitant there.
As El Toro noted, I've found soaking time [counted in months] usually helped enough, but I doubt it's the best or quickest.
What about that clutch? Somehow I can see it coming to digging it out and pulling it all apart, but with mine I was able to get enough penetrating oil into it without pulling it out that it went from stuck to sticky [probably not even the latter if I ran it more].
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
