Re: Farmall M Noise: Governor or Manifold Leak?
Posted by ChadS on September 22, 2008 at 16:13:14 from (4.224.78.53):
In Reply to: Re: Farmall M Noise: Governor or Manifold Leak? posted by Kerwin on September 22, 2008 at 13:58:10:
There is always the risk of fire, but you should do this while its cold, just fire it up ideling, and spray it down where the head meets the manifold. if its a vacuum leak it should change sound by smoothing out a little. Id say if you do tighten the nuts on the manifold,,,, warm it up real good,, then try to turn em,,,, the heat should help them turn a little easier. Ive had to fix broken studs from this, not fun, but it could happen so be careful. Chad
