Re: Farmall H, what jobs did they do on the farm?
Posted by Andy Motteberg on September 22, 2008 at 18:05:37 from (4.143.216.112):
In Reply to: Re: Farmall H, what jobs did they do on the farm? posted by I need a handle on September 22, 2008 at 17:53:31:
As long as the bolts are kept tight on the wheels, they should not break. If the bolts are loose, the clamps can break from the rim wobbling around on the hub.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
