Re: 806 IH Diesel with TA
Posted by GeneMO on September 22, 2008 at 19:09:42 from (71.49.76.2):
In Reply to: 806 IH Diesel with TA posted by RCC on September 22, 2008 at 17:18:46:
I am real poor help here, but hopefully someone more knowledgeable will chip in.
Take off the hood right in front of the throttle.
Blow all the junk off with an airhose. It's been so long, I kinda forget, but there is a shaft that has an "arm" on it. That broke loose on mine and I had to get it in the right gear, then weld the arm back to the shaft. with the hood off I hope you can work the shifter back and forth and see where the problem lays.
This was on a late model 706, but hope it helps.
Gene
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
