Re: Stuck 22-36
Posted by gregk on September 22, 2008 at 19:10:52 from (12.186.47.227):
In Reply to: Stuck 22-36 posted by spiffy1 on September 21, 2008 at 18:46:52:
If it is like a 10-20 and you can remove the flywheel cover to gently get a pry-bar on the flywheel teeth it will give you more leverage than the hand crank. Gently is the key word as you can break off flywheel teeth if you are too rough
