Re: Farmall H, what jobs did they do on the farm?
Posted by JImmy King on September 22, 2008 at 21:46:30 from (207.69.137.43):
In Reply to: Farmall H, what jobs did they do on the farm? posted by Rick in MD on September 22, 2008 at 13:30:06:
Rick I will be 67 in Nov. I still live on the farm I grew up on My Granddad owned it then, and we farmed my Great Grand Mother"s farm also total of about 400 acres farmable. My Uncle had a B, Dad had a Super A, and Granddad had an H. Thge H pulled a 3 disc plow 6 ft tamden disc with 7 ft drag behind it or a 7 ft field cutivater with drag. Pulled a 1 row Alis field chopper ( not good though ) a 28 inch IHC seperator, later a 7 ft MH clipper combine and a 69 N H baler. The B and A pulled the drill, a 50T IHC baler hay wagons bundle wagons the binder hay rake but raked a lot with the H also. Dad had a mounted wood saw for the H and another uncle had a loader for it. Untill we put a power unit on the chopper we ended up pulling it with a neighbors U MM and pulled the silage wagons with the H.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
