Posted by Owen Aaland on September 23, 2008 at 05:25:42 from (65.161.86.107):
In Reply to: 806 hydraulic problems posted by Brad Motheral on September 22, 2008 at 22:24:53:
Before you start digging into the hydraulic pump you need to find out how the system functions when it is working. If the steering, brakes, and TA work OK at low idle when warm, then the pump is most likely alright. The most likely cause for your problem then would be an air leak on the suction side between the MCV pump and the hydraulic filter. It is very common for the O-ring between the clutch housing and the rear frame to become hardened and allow air to enter. If that is the problem, the simple way to work around it is to run the system about five gallons over full.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
