Re: 806 IH Diesel with TA
Posted by Owen Aaland on September 23, 2008 at 05:40:59 from (65.161.86.107):
In Reply to: 806 IH Diesel with TA posted by RCC on September 22, 2008 at 17:18:46:
That tractor was built with a shift fork held in place on the shift rail with a bolt through the fork and rail. If it still has the original shift rail, there is a good possibility that the rail broke through the bolt hole and the fork fell out of place.
A new shift rail can be installed from the rear through the access hole above the PTO. A short piece of 3/4" heater hose to hold the new rail on a pipe or shaft will allow you to each far enough forward to start the new rain in the hole in the rear frame.
It would be a good idea to update the park lock at the same time.
