Re: Farmall A clutch problem
Posted by P and R Pete on September 23, 2008 at 11:08:29 from (205.238.236.103):
In Reply to: Farmall A clutch problem posted by john in pennsylvania on September 23, 2008 at 07:23:06:
John, just in case you've never adjusted your clutch yet, here's a picture from my Super-A, where the adjustment is done. The inspection hole is at the rear of the torque tube, underneath. (I'm trusting that the A and SA are the same)
third party image
#1 is the yoke attached to the brake pedal, and it's 'horseshoe'-shaped, and loops up and over the nuts and threaded rod and down again, and is all one piece.
At #2, there is a hole in the yoke which is NOT threaded, (much as it may look like it is), and is there so that the threaded rod can move back and through the yoke.
#3 are the two nuts that do the adjusting. The pedal pushes the rod forward, which pushes the throwout bearing forward to engage on the clutch. So if your clutch is already too tight, you have to work those nuts to get the rod to move rearward a sufficient amount to get an inch of freeplay at the pedal, like Dave already said.
If I don't have this bass-ackward (LOL), loosening the right nut, and 'tightening' the left nut will pull the rod rearward. When you have it right, re-tightening the right nut will lock the adjustment.
