Re: Farmall C clutch froze
Posted by old on September 23, 2008 at 13:20:07 from (4.245.7.117):
In Reply to: Farmall C clutch froze posted by jbird on September 23, 2008 at 12:55:11:
Theirs a number of way to pop it free that may or may not work. One is to hook up a wagon etc behind it and start it in as high a gear as you can and take it for a drive with the pedal held down. Another way is to pull the starter off and block the pedal down then spray brake cleaner into the clutch area, turn the engine over a little at a time so as to cover the whole clutch. If it has an inspection hole that lets you see the clutch disk you can some times take a punch etc and tap on the disk to help free it up. If you use the tap method be careful not to brake up the disk or you will have to replace it
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
