Posted by J.J. from Afton on September 24, 2008 at 09:39:13 from (139.225.250.243):
In Reply to: W4 rear axle seals posted by RVS on September 24, 2008 at 06:02:24:
That is a real cool club project.
Best way that Ive seen and used is a large T puller. place a 1/2" thick round piece of steel against the end of the axle, works best if theres a small hole in the center to place the tip of the threaded rod from the puller. Than use to large bolts to hold the bar of the puller to the center, be sure to place flat washers on the bolts so the nut is not pulled against the center. Than using a 3/4 impact tighten the rod of the T puller to pull the center off the axle. 3/4 air powered impact works best, cause using a bigger one will likely ruin the threaded rod of the T-puller, been there done that. You may end up having to heat the area of the center on the axle in order to expand it so it might slide easier. Also when you put the center back on its not a bad idea to coat the splines of the axle with anti-seize after ther are cleaned up, just in case you ever have to pull the center off again.
Hope this helps...........Jordan
Heres another picture just showing a better view of the T-puller.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
