Re: is the SurepC Case (rear frame) same as a C
Posted by ScottyHOMEy on September 24, 2008 at 17:42:34 from (71.241.210.41):
In Reply to: is the SurepC Case (rear frame) same as a C posted by CodyNC on September 24, 2008 at 16:23:39:
They're interchangeable as far as bolting up and being able to drive it, but that's about it. A C rear-end will not be machined for the disc brake surfaces like a Super. If the pedals and linkages for the band brakes (a whole different beast from the linkage on the SuperC discs) came with it, though, you'd be all right in that regard.
Not at all certain about this part, but I don't believe the castings for the rear ends of the C have all the bolsters and fittings cast or machined into them to mount the Fast Hitch. Look real closely at that.
