Re: Stuck 22-36
Posted by spiffy1 on September 24, 2008 at 21:45:02 from (70.41.136.71):
In Reply to: Stuck 22-36 posted by Clarkbug on September 21, 2008 at 18:46:52:
gregk said: (quoted from post at 21:10:52 09/22/08) If it is like a 10-20 and you can remove the flywheel cover to gently get a pry-bar on the flywheel teeth it will give you more leverage than the hand crank. Gently is the key word as you can break off flywheel teeth if you are too rough
I think that is possible, but afraid gentle isn't often my strong suit with a prybar in hand! :oops:
Haven't worked with it much more, but did check the pan plug - a pint of water! So maybe the governor housing was tore apart before it was shedded, condensation was nastier than I suspected, or mouse urine - not sure if the latter is probable, but there was a nest in the manifold. Also noticed the upper exhaust divertor wasn't seated on one side - maybe 3/8" !
I'm afraid this thing may be planning to put a up a bit of a fight. Next step probably pull the valve cover, and see if I can bring up the open valves. Then at least I can put some air pressure to those two also.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
