In a lot of cases like that you'll find that the carb has been replaced, and the geometry of the linkage on the new carb (length and angle of the throttle arm, for instance) is enough different to throw things off.
I've had them go both ways. I replaced the Carter on my SuperC with a Zenith, and it operated over the bottom two thirds of the total throw of the lever. Replaced the rotted out Zenith on my BN with a new Zenith, and it only wanted to operate over the top two thirds. In that case, though, unlike yours, the bottom third did nothing, it didn't kill the engine.
Once I got the left side squared away on both, I did some fiddlin' with the springs on either side of the block connecting the control rod and the governor, and I've got all but the last two notches to work with on the SuperC. The BN has been a little less cooperative and required some straightening and adjustment in the angles on the control, but I'm gainin' on it. Got the full range for engine speed on both, low to high idle, just not as fine an adjustment between engine speeds as you would get with the full use of the lever.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
