Re: converting 12+ ground to 12v- ground ?
Posted by John T on September 25, 2008 at 07:46:09 from (66.244.97.31):
In Reply to: converting 12+ ground to 12v- ground ? posted by glennster on September 25, 2008 at 07:28:35:
You got it covered there Glenster::::::
Wire her up,,,,,,Connect Battery at Neg ground,,,,,,,,,,POLARIZE the Genny BEFORE you start it,,,,,,,,,,Coil is polarity sensitive i.e. at Neg round its lil + receives ignition switched voltage while its lil - wires to distributor,,,,,,,,,In the even the ammeter isnt wired correct, simply swap its leads i.e. wire it so with tractor off if you turn on lights or ignition it swings over to - discharge then swings to + charge when running at RPM.......
Woooooooo Hooooooooooo
John T
