Re: wd9 / super m hydraulic pump
Posted by dwsc on September 25, 2008 at 16:15:05 from (4.252.71.66):
In Reply to: Re: wd9 / super m hydraulic pump posted by BOBM25 on September 25, 2008 at 12:35:20:
thanks for looking, my pump is bad and I need a pump, I found a w9 tractor that is gas that has the hydraulic system on it but i wasn't sure that it would work
