Posted by Hugh MacKay on September 25, 2008 at 18:43:42 from (209.226.247.82):
In Reply to: Rear Wheel Profiles ??? posted by underdog57 on September 25, 2008 at 17:58:30:
Bob: All tires are stamped on sidewall for the ideal rim size. That suggested rim size will give the best traction, for that particular tire.
Farmall Hs and Ms used deep center drop rims, spicific to those tractors H probably used the 10" rim, I think M would be wider.
About the time Supers were introduced the double bead rim was also introduced. That same double bead rim was used by Deere, Oliver, Cockshutt, etc. and just about every manufacturer. The new rims were supplied by outside suppliers. You can't mix double bead rims on older type wheels.
You can however, change the wheels at the axles, thus your tractor could be equipped for double bead rims.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
