Re: H oilpan leaking
Posted by Andy Motteberg on September 25, 2008 at 22:06:42 from (4.143.220.33):
In Reply to: H oilpan leaking posted by littlered on September 25, 2008 at 20:48:44:
Did you make sure that the oil pan surface is clean, free of dirt and old gasket remains? Is the oil pan surface warped or out on shape? Did you make sure both surfaces were clean and smooth when you put it together? How tight did you tighten the bolts? It is easy to over tighten and if they are too tight, it will split the gasket, if they are too loose it will also leak.
