Re: What would you do???
Posted by mkirsch on September 26, 2008 at 05:52:35 from (64.80.108.52):
In Reply to: What would you do??? posted by GeneMO on September 26, 2008 at 05:45:32:
Rather than scrap it, why not just market it the same way you did before? Figure out what it would cost to advertise, then charge that amount. Put the words, "original buyer abandoned, must remove immediately" in the ad. If it doesn't bring out the original buyer, it will certainly sell quickly, and worst case you are out a few dollars for advertising.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
