Re: What would you do???
Posted by El Toro on September 26, 2008 at 06:16:36 from (64.12.116.73):
In Reply to: What would you do??? posted by AJ Clark on September 26, 2008 at 05:35:47:
If you have his name you can do a search for him.
Try ussearch.com or peoplefind.com Hal
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
