Re: brake disc thickness
Posted by bc on September 26, 2008 at 09:57:36 from (70.130.55.114):
In Reply to: brake disc thickness posted by bill b va on September 26, 2008 at 09:49:19:
Not sure on a 350 but maybe plus or minus around a half inch. Are they worn smooth or are there still vertical grooves in the disks? If yours has the external bolt on type brake housing with the pull expanders between two disks, that inside surface can wear down and you have to have a machine shop shave the housing down.
