Re: H oilpan leaking
Posted by Underwood on September 26, 2008 at 12:20:32 from (4.164.171.241):
In Reply to: H oilpan leaking posted by littlered on September 25, 2008 at 20:48:44:
I replaced the oil pan gasket on a 656 and had a similar problem. Found that some of the pan bolt holes are tapped all the way through to the interior of the block. Oil can follow from the end of the bolt, around the bolt threads and through the bolt holes, through the holes for the bolts in the gasket and wind up on the head of the bolt. The fix is to put some thread sealer or gasket sealer on the threads of the bolt before you thread them in.
