Re: Farmall 400 retiming ignition after hyd Pump removal
Posted by Owen Aaland on September 27, 2008 at 11:13:57 from (65.161.86.107):
In Reply to: Farmall 400 retiming ignition after hyd Pump removal posted by geoffdrivesadiesel on September 27, 2008 at 10:07:38:
Unless you have a magneto just ignore the marks when you install it.
Separate the distributor from the distributor adaptor. Install the adapter. Turn the engine until you have number one TDC on the compression stroke. Line the rotor up to the number terminal on the cap and install the distributor. Retard the distributor and then advance it until the points just start to open. You should be within a couple of degrees of where you want to be.
