Re: Remote outlet flow adjustment
Posted by Allan In NE on September 28, 2008 at 05:50:37 from (148.78.243.24):
In Reply to: Remote outlet flow adjustment posted by Jeff Benjamin on September 27, 2008 at 19:16:55:
Pull the rear pump and check that o-ring and gasket. They have a real nasty habit of leaking internally.
If you are satisfied that they are/were good, replace the pump.
Allan
third party image
