Re: Remote outlet flow adjustment
Posted by IaGary on September 28, 2008 at 06:05:06 from (207.177.17.200):
In Reply to: Remote outlet flow adjustment posted by Jeff Benjamin on September 27, 2008 at 19:16:55:
While we are on this subject. I have a 1066 that does that when the 3pt. lever is in the far foward position.
If I move the lever back a ways every thing works just fine.
What position is your 3pt. lever in?
I believe the 3pt. lever gives you the ability to set the speed of the hydraulics.
Am I correct?
Gary
