Re: sealing head gasket on damaged block
Posted by John G. Hasler on September 28, 2008 at 08:12:52 from (69.179.127.181):
In Reply to: sealing head gasket on damaged block posted by sgtbull on September 27, 2008 at 20:15:27:
I successfully repaired a pitted manifold with "Devcon Metal Patch And Fill" (JB Weld should do as well). I just applied a thin coat and sanded it down until the pits were filled flush with the undamaged surface. May take several coats.
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
