Won't Start after rain
Posted by TomH in PA on September 28, 2008 at 13:46:17 from (72.171.0.149):
Finally figured out why my 504 wouldn't start after being out in the rain. The oil bath air cleaner had about a cup of water in it that caused the reservoir to be overfilled. Cleaned that milky mess out, and cleaned all the oil off the spark plugs and she started right up.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
