Re: 966 tick issue, were to start?
Posted by RichH on September 28, 2008 at 20:11:15 from (98.132.227.75):
In Reply to: 966 tick issue, were to start? posted by Kelly C on September 28, 2008 at 18:26:46:
First adjust the valves. If a valve on number one is really lose, or any other cylinder, maybe a lobe on the cam going bad and or a lifter going bad. If unburned fuel is coming out of number one exhaust port, loosen the fuel injector line at the nozzle just alittle and see if engine rpm or noise changes any. If the noise changes but the rpm doesn't then I would say you have a bad injector
