Posted by ScottyHOMEy on September 29, 2008 at 02:50:07 from (70.105.248.74):
In Reply to: Super A belt pulley posted by Jay Poole on September 29, 2008 at 02:33:39:
Are you talking about the actual belt pulley or a pulley mounted to the PTO shaft to drive the mower? You'll want to have that terminology correct if you go to order new seals, just in case they might be different for each application. (The belt pulley is oriented perpendicular to the long axis of the tractor, and the PTO is parallel to that axis.)
In either case, your parts book will show a single seal on either shaft. The new reality is that the shells of the seals now available are not as deep as the originals, and it is quite common to put two seals on those shafts, one over the other. This is sometimes also and effective cure for a spot in the shaft that might have been worn down far enough that a new seal on that same spot would still leak. If in using two seals you are able to get the seal surfaces on different, unworn spots on the shaft, you should get a good seal. Some folks go so far as to pack grease between the two seals. That might be overkill if you've got a good surface on the shaft to seal to, but falls into the "can't hurt, might help" category in my view.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
