Re: Super A belt pulley
Posted by Gene Bender on September 29, 2008 at 05:45:15 from (67.55.226.167):
In Reply to: Super A belt pulley posted by Jay Poole on September 29, 2008 at 02:33:39:
When you removed the pulley what did you do with the narrow bushing that fits around the shaft and the O.D.fits the seal I.D. Then if you arent going to replace the pulley you need the long bushing and large washer with a cap screw to hold the bushing on the shaft it will also keep the narrow bushing that rides in the seal. Just helped a fellow do his on an A that he is restoring. You can make the long bushing and make it longer so the end will ride in the seal. A flat washer and cap screw will hold it on.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
