TC - If your M has a live pump the most probable cause is a failing camshaft drive gear. Typically the web between the gear teeth and hub fractures, or the cam gear retaining nut loosens/falls off.
The gear will still drive the cam more or less in time - so the engine will still run. But you'll hear a slap or clunk twice every crank revolution as the gear "flops" fore and aft inside the timing cover.
Repair is straightforward - I've replaced several Super M/400 cam gears. However there's some heavy parts must be removed (entire front end/bolster assembly) to get at the timing cover. Also the nut on the the front of the crankshaft must be removed. The nut is BIG and located in a recess. It requires a 2-1/2" socket - a size not usually in the average M owners toolbox!
However before you tear the tractor apart carefully check also the fan blade/water pump assembly. A loose fan blade or failing water pump bearing can cause ominous sounds at the front of the engine too.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
