Re: Farmall H starts to miss after warmed up
Posted by teddy52food on September 29, 2008 at 10:17:18 from (209.237.111.169):
In Reply to: Farmall H starts to miss after warmed up posted by slydog on September 29, 2008 at 08:44:21:
When you changed the points, did you put a new condenser in too? Check the points and if they have a pit on one side and a peak built up on the other, the condenser is bad. I would put in both and if that doesn't help, I would change the coil next. If the valve lash is not enough, you should notice the exaust change sounds as it gets hot.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
