Re: Farmall H upper bolster oil or grease?
Posted by Dave_Id on September 29, 2008 at 12:48:40 from (70.114.251.54):
In Reply to: Farmall H upper bolster oil or grease? posted by AH64Dattack on September 29, 2008 at 12:34:07:
I would have thought that originally, it would have been the same gear oil as the tranny. May I make a suggestion. I would recommend the gear grease that are used in the JD baler lube systems. It appears to be light grease, almost liquid. It'll stay in those seals a lot longer, and your steering won't get real stiff over time with regular grease.
