Hi JB, I looked in my OEM book for tractors with gas C-175 engine and they are 454 & 464. The 444 was either BD154 Diesel or C-153 gas. The way to tell the difference is the gear shift. The 444 has a gear shift on top of the transmission cover with a HI/LO lever on the left of the gear shift. The 454,464 has a gear shift by the left fender that has a 1-4 lever and a HI/LO/REV lever.
The clutches are different, the 444 clutch is a two stage clutch, 1/2 wave down stops transmission, all the way to floor stops transmission & PTO. Clutch is adjusted by loosening 2 bolts on clutch lever and rotating clutch release shaft with wrench until 7/8 inch of free travel is acquired. On 454/464, clutch is single stage and only controls transmission. The PTO is controlled by lever by right rear of seat. The clutch is adjusted by removing pin from clutch rod and turning clevis until about 3/4 inch free travel is acquired.
BUT, I believe your problem is the clutch disk has stuck to the flywheel or the pressure plate. Just like disk brakes on a car after a rain, the metallic compound it the clutch pads rust onto the flywheel and stick.
Search the archives for "stuck clutch" and you will find various solutions. My first attempt would be to start it in gear, holding the clutch down and applying the brakes to see if the clutch will break free. BE VERY CAREFULL have a finger on the OFF switch.
To prevent clutch from sticking again, use tractor more frequently or when parked for a long time, rest loader & back hoe buckets on ground, block rear wheels and tie or block clutch lever in disengage position.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
