Re: Weight of Fast Hitch
Posted by D Slater on September 29, 2008 at 15:43:22 from (71.182.16.50):
In Reply to: Re: Weight of Fast Hitch posted by RustyFarmall on September 29, 2008 at 13:57:05:
Yes even though the rear end housing is narrower on a H or 300 size than the bigger tractors, the notch in axle housing for clamps is a greater distance from bolt up point on rear end housing than M size. Only problem is the square tube that axle housing clamp bolts pass through at front won't fit in notch on axle housing of H size if tube is from most M or SM. On some tubes that take the 7/8 clamp bolts and are more rounded and common on 400 and up tractors, the more rounded side will usualy fit in H size notch.
