Re: 9 bolt hubs
Posted by mike french on September 29, 2008 at 16:08:41 from (76.2.189.202):
In Reply to: 9 bolt hubs posted by Pat-CT on September 29, 2008 at 11:45:22:
Oliver 77's will work with a little help, either have the key on the hub cut straight or grind the axle key slot. Some 460 Utilities had adjustable axles with 8 bolt hubs, but not 9. I put a set on a H and used combine wheels and tires, good luck.
