Re: Farmall H upper bolster oil or grease?
Posted by Gene Bender on September 29, 2008 at 16:53:07 from (67.55.226.167):
In Reply to: Farmall H upper bolster oil or grease? posted by AH64Dattack on September 29, 2008 at 12:34:07:
I would rebuild it and use 150wt as it just mite work well if the journals where the seals go have some wear.
