Re: Cub won't go in sub-freezing weather
Posted by James Rumph on September 29, 2008 at 17:57:02 from (24.192.125.175):
In Reply to: Cub won't go in sub-freezing weather posted by CRS5357 on September 29, 2008 at 07:41:12:
I have found my 55 hard shifting in the winter, but it was due to 90 weight oil.
The gear lube gets real thick in the cold weather, making for poor shifting.
I found that by running Syn 90 weight gear oil that shifting is very smooth in the cold weather.
I bought Royal Purple Syn 90 weight gear oil and what a differance.
Last winter here in Michigan was real good for snow fall and i plowed alot , no leaks and shifting smooth.
I do have to agree with everyone " you have water".
The lower pans on the bull gears hold 1 quart of oil i do believe.
The trans has a plug on the left side of the trans that tells you that it is full to the correct level. 1 1/2 quarts i do believe.
If you decide to run the normal oil and it is stiff shifting , let the pto run.
I found that letting the pto run warms up the oil quicker as opposed to it not running.
Hope some of my findings help you.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
