Re: Rear axle strength...running duals on 400
Posted by Hugh MacKay on September 29, 2008 at 20:11:12 from (209.226.247.4):
In Reply to: Rear axle strength...running duals on 400 posted by geoffdrivesadiesel on September 29, 2008 at 18:33:25:
Geoff: Duals work great for flotation. Just don't go thinking your going to double the traction by adding weight. Stay away from maximum draw pulls in 1st or 2nd gear.
I dualed several tractors over the years, in every case I dumped calcium chloride from single wheels and went with no weight added in or on duals. My most hours of service were with 1066 and 560, they actually pulled the loads much easier in a field situation. They wont pull as much on hard road or black top, but most of us don't do a lot of farming on the road.
