Posted by Janicholson on September 29, 2008 at 20:42:41 from (66.188.163.79):
In Reply to: oil pump posted by smitty59 on September 29, 2008 at 17:26:31:
If it has a flathead engine (regular Cubs do, I am not positive about the Lowboy), The oil pump is built into the block as a part of the block casting. It is at the rear on the same side as the filter. The engine needs to be separated from the torque tube, and the flywheel removed to get to it. If it has lost prime, and has no oil pressure, Filling the system with a squirt type oilcan by attaching a hose to the hole in the block near the oil filter (allen head plug in it) then pumping in several oilcan loads of 40 wt engine oil, will usually get it primed and going. Start them often to keep them primed, maybe every two weeks minimum. JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
