Re: Extra mark on M crankshaft pulley
Posted by Janicholson on September 29, 2008 at 20:47:09 from (66.188.163.79):
In Reply to: Extra mark on M crankshaft pulley posted by Dr. Bert on September 29, 2008 at 17:20:27:
NebraskaKirk is correct. The second mark is TDC the first is the running timing and needs a timing light to use (and a tach). JimN
