Re: Cub won't go in sub-freezing weather
Posted by bear32055 on September 30, 2008 at 03:58:51 from (67.43.118.180):
In Reply to: Cub won't go in sub-freezing weather posted by CRS5357 on September 29, 2008 at 07:41:12:
i would bet the farm its water mixed in with tranny fluid.Mine was so bad when i got it i had to change it ,run ,then change it 3 times till the oil stayed clear.Dont"t forget there is a drain plug for pto too.If you dont drain it there as well it will mix with the new fluid eventually.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
