Re: Clutch on my M
Posted by Janicholson on September 30, 2008 at 11:55:53 from (199.17.55.128):
In Reply to: Clutch on my M posted by F-Dean on September 30, 2008 at 11:46:55:
It could be, but it is more likely that the disk is warped enough to drag when the clutch is pushed in all the way. Changing it is pretty easy W/O split.
Or the pilot bearing is dry and driving the clutch shaft when it should be free.
Or the splines are worn on the clutch shaft causing the new disk to run against the FW or PP.
A new/different good shaft will fix this. JimN
