Re: Rear axle strength...running duals on 400
Posted by Steven f/AZ on September 30, 2008 at 16:39:41 from (24.121.250.95):
In Reply to: Rear axle strength...running duals on 400 posted by geoffdrivesadiesel on September 29, 2008 at 18:33:25:
In my experience, duals have helped with traction. An example would be pulling the 22' chisel plow with 12" sweeps on it with our 1086 - with singles on back (fluid filled plus cast weights) it would pull it, but noticably spinning. We put the duals on (steel rims, no weights, no fluid) and it pulled it without much slippage at all.
I've had other experiences where a tractor with single rear wheels would spin, while another with duals (or just putting the duals on) would work much better as far as traction.
Same principle as those who race cars - more rubber on the road/ground = more traction.
