Re: W6 rear end fluid
Posted by randy hall on October 01, 2008 at 06:14:49 from (209.143.0.64):
In Reply to: W6 rear end fluid posted by Wade Lentz on October 01, 2008 at 02:53:30:
the w=6 is the same casting as an m. the oil level plug is on the left side on the transmission part of the casting. i use 140 weight gear oil so it won't leak as easy, but if you are going to use it much in cold weather 90 would probably be better. it holds 56 quarts.
