Check around the coil for a ballast resister, If installed it should be roughly 4 inches long and have one wire attached at each end of it. It will be made of a white ceramic material. If not equipped you will want to install one. This will cut the 12 volts down closer to 6 volts for the six volt coil. If still equiped with the 6 volt generator it will not charge the battery, But the tractor will still run for long periods of time without a charging system. My personal opinion is to leave our antique tractors with the 6 volt system that they were designed with. If the engine and electrical system is all in good working order, and the tractor tuned up properly , They will easily start every time with the six volt sysytem.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
