Re: IH 674 Diesel - Air in system?
Posted by Ryan Edson on October 01, 2008 at 13:33:27 from (206.171.54.241):
In Reply to: IH 674 Diesel - Air in system? posted by Floridaboy on October 01, 2008 at 11:28:40:
After replacing the filter, did you open the bleeder screw on top of the housing and let fuel come out (bleed the filter)? Did you replace the secondary filter? If so, did you bleed the secondary filter? Did you check the fuel flow at the tank, by removing or loosing the fuel lines? If you have fuel at all three locations, with a strong battery, crack all four injector lines at the back of the pump and crank the motor over. If after a minute of cranking, no fuel comes out, chance is that you may need to rebuild the pump.
