Re: McCormick-Deering bad motor - which rebuilt kit??????
Posted by El Toro on October 01, 2008 at 13:33:42 from (205.188.116.73):
In Reply to: McCormick-Deering bad motor - which rebuilt kit?????? posted by Dave Koenigsfeld on October 01, 2008 at 13:11:18:
I would try another auto machine shop to see if they can free the pistons with heat then use a hydraulic press. They have sleeves so they may press out with the pistons. The rods can probably be rebabbitted and L.A. Sleeve can make new sleeves if Rice Equipment doesn't have any. Pour lots of ATF on top of the pistons and let them soak. Hal
