I have found out that a machine shop is the worst place to take one of these motors to.There used to working on newer style engines and arent use to breaking motors loose,I douth if this motor needs every thing new,Theres a special trick to looseing these motors,its called a sledge hammer.fill the cylinders with deisel fuel and let it burn,do this several times while hitting the top of the pistons.I use a peice of 3/4 flat steel on top of the pistons to keep from damaging them and hit each one of them with a 20lb hammer.if you can use a 4ft pipe in the flywheel holes this works also.This sounds crude but Ive done about 10 of these type of motors,It is easier to leave the motor in the tractor,Usally 10-20 dont stick very bad,becaues of the way the manifold is
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
