Re: International 300 Utility TA Lubricants
Posted by John Cipperley on October 01, 2008 at 17:20:20 from (12.30.112.98):
In Reply to: Re: International 300 Utility TA Lubricants posted by Janicholson on September 28, 2008 at 15:12:14:
Thank you, but under the TA gear cluster is a reservoir area, probably only hold a quart? Does the gearing get lubricated from here or by flow from transmission? I agree that the area under TA clutch should be dry, and yes, we have replaced the seal on trans, and PTO sides. We are putting new clutch, pressure plate and throw out bearing in. Should all be 80/90 wt gear oil? IT manual does not specify any of this info. Thanks for your help! JC
